BringBackDOS
Jan 15, 2017Follower
What are the differences Between the R6250 and the C6250 Cable / Modem / Routers?
What are the differences Between the R6250 and the C6250 Cable / Modem / Routers? I'm shopping for a New Cable Modem so as to circumnavigate TWC's Monthly Cable Modem Fees. I have one picked out but of course there's a wrench in the cog. Any assistance will be greatly appreciated.
Best Regards,
John / Owego, NY
You are not alone in this quest.
Here's what Google found:
How to Beat TWC and Comcast's Bull**bleep** Modem Rental Fees
Lease a Modem from TWC or Buy Your Own Modem
The second one has a list of "approved" modems, but as well as netwrks's ever sound advice, it might also be worth saying that any lists of compatible modems that ISPs, or other websites, provide are quite likely to be out of date.
You would do well to sound out other customers of your ISP to see if anyone has managed to use one of the modems that you fancy even if it isn't on these lists.
- adriahnoAspirant
I also own one C6250.
Do you think is possible to transform C6250 into a R6250? Or at least to us it as a wifi repeater?
R6250 is a router, no modem.
Some modems can work as "modem only". But even you can do it with the C6250 it has only two LAN ports on the back.
What is it that you want to achieve?
- netwrksMaster
The C6250 is a cable modem router combo: http://www.downloads.netgear.com/files/GDC/datasheet/en/C6250.pdf
The R6250 is a router (no modem): http://www.downloads.netgear.com/files/GDC/R6250/R6250_DS_20Jun1374-73764.pdf
Before you buy a cable modem / router combo, ensure your ISP snaction's the cable modem part. For alot of reason's ISP's don't support, just any modem..
