benwilde's avatar
benwilde
What can I tell Comcast to get past 'Access Denied'?
Hello amazing Netgear community!
I got tired of paying Comcast to rent their hardware and bought a C7000v2 a few months ago. Generally, things have worked fine, but over the last few weeks, we've been experiencing long periods of internet outage (a few hours at a time). I've tried all of the basic stuff (having Comcast "send the code" to the router, rebooting, even factory resetting), but it seems to be a problem that only resolves itself over time, despite Comcast's website not reporting any outages in our area.
Well, it happened again this morning, and I decided to do a little more digging. After seeing the dreaded yellow (!) sign next to my wifi connection, I connected to the router, where the "Cable Connection" tile on the main screen was red and said "In Progress." I drilled in, and over a period of a few minutes, noticed that it seemed to be cycling through three states:
  1. Not yet aquiring a downstream channel
  2. Locked on a downstream channel and Connectivity State == "Phy Synchronized"
  3. Locked on a downstream channel and Connectivity State == "Access Denied"
I looked online first, and it generally seemed like other people who have encountered this issue haven't had any luck actually calling a Comcast technician, so I'd rather avoid going down that path. There were some earlier threads with a mention of asking Comcast to make a switch from IPv4 to IPv6, but others were skeptical about that solution.
So, my question is this: Given that I'm almost positive that this issue relates to Comcast not playing nicely with my Netgear hardware, AND the fact that things have worked in the past (so it doesn't seem related to hardware/cables/etc), is there some pre-baked solution that I can call Comcast and ask them to do remotely, without spending hours on the phone and working my way through the tiers of support?
Thanks in advance, and I'm happy to provide more info if it would help!
-Ben
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Please post 3 items here:
    1. EVENT LOGS
    2. Connection table (which shows all the power info)
    3. Log (aka network logs)
    You have described problem nicely (but incomplete) due to missing logs. Please help to provide logs.
    • benwilde's avatar
      benwilde
      Thanks for the quick reply. It's great to see Netgear employees monitoring the community forums and looking for ways to help.
      I may have pinned this on Comcast a little prematurely... attached is a .pdf file with my logs. It looks like there are some DDOS entries, similar to what was described in in this thread. I'd love any help with a resolution.
      • vkdelta's avatar
        vkdelta
        benwilde
        where do you see "access denied"
        you have serious cabling problem in your house (or apartment or condo). One of the key problems why you are seeing problems is your upstream power. It is beyond specs and that is one of the reasons device is not bonding. there are other B-INIT ranging failures which will cause disconnections and even delays in coming online.
        to get an indepedent 3rd party unbiased opinion, you are welcome to post it on DSLR forums (below link) where there are multiple experts. I am sure, they will have similar response. You will get quick response on that forum as well.
        https://www.dslreports.com/forum/comcast
