JGs3
Jun 13, 2020Follower
What internet provider speed can nighthawk C7000V2 handle
Hey all,
Essentially Cox is telling me that my C7000V2 Nighthawk is not compatable with their 500MBPS internet package because it is to slow. The only reason I want this package is it is 40-30$ cheaper than my current 300 MBPS package and still cheaper than the 150 MBPS package. Overall I am very happy with this combo router / modem
Netgear boast that it can handel speeds up to 960 MBPS. if you look the item up you can download a PDF of it's specs from the netgear website.I have copy and pasted the specs below.
Nighthawk®—AC1900 WiFi Cable Modem RouterData SheetC7000Performance & Use• AC1900 WiFi—up to 1.9 Gbps• 1.6GHz processor boosts performance for streaming & gaming• Two-in-One—Cable Modem + WiFi Router• Save up to $120 a year1—No rental fees• Ideal for XFINITY® Blast/Extreme, Spectrum® data plans• Beamforming+ for whole home HD coverage• 24x8 Channel Bonding enables up to 960 Mbps‡ download speeds• Works with cable Internet providers like XFINITY®from Comcast, Spectrum®, Cox®, Cablevision &
Amazon states only 400 MBPS in the description
https://www.amazon.com/NETGEAR-Nighthawk-Certified-Xfinity-Spectrum/dp/B0781Z5PCL/ref=as_li_ss_tl?ie=UTF8&qid=1532907800&sr=8-5&keywords=motorola+ac1900+wi-fi+gigabit+router+and+modem&linkCode=sl1&tag=modem-router-combo-20&linkId=fe31efb7f534d2bb997b7470b68d8a2d&language=en_US
Who is right? what should I do? call cox up and tell them they are wrong? Or is netgear false advertising? Or am I just really missing something?
Thanks in advance,
J
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
The datasheet will tell you more.If you need more specific information, you might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Cable Modems & Routers- FURRYe38Guru - Experienced User
Cox seems to have approved FW for the C7000 series gateway modems:
