numbertwo
Jul 27, 2017Aspirant
What is happening in my logs for my modem/router? Dos, Remote and other stuff.
So i run malwarebyts rootkit scanner and it found so virus or infected rootkits(idk how or if they are different). Anyways i decided i should also check my logs for my router/modem and sure enough if...
TheEther
Jul 27, 2017Guru
While you are at it, you might want to disable UPnP on the router, unless you need it for gaming. You should change the admin password on the router, too.
numbertwo
yea i changed my password for my router because it had the default one(password thats bad probably) and the wifi password too which had a more complex password. So was my phone just Dos a website or what was it doing and what is that remote thing?
- TheEtherJul 28, 2017Guru
The DoS attack log doesn't say much. All we can say is that your router saw the traffic and reported it as malicious.
The [LAN access from remote] message means that one of your devices (the one at 192.168.0.11) was accessed by a machine on the Internet. This is not necessarily bad. If you had deliberately opened access to that device for gaming or for sharing files, then it's normal to see that message.
- numbertwoJul 28, 2017Aspirant
I looked up the ip source for the lan access from remote and it was microsofte doing gods knows what. I think it was targeting my xbox or my pc, I can't remember what device had that ip the xbox or pc. So for anyone still reading this and having this problem. What i did to fix it was just factory reset the modem and testing to see if it would do it again(when u factory reset make sure to enable all protection settings and change password). I added a device a day and check to see if it still happen and so far its not. The last device i have to connect is my phone, which i belive was the source of this problem. I factory reseted my phone too(iphone6). I guess we will find out tomorrow if i have to replace my phone or just keep it. I've been looking for a reason to upgrade my phone to another iphone or an android anyways.
