freddiebarker
Dec 29, 2016Aspirant
What is the difference between medium and low firewall security?
I would like to know what the difference is between the high, medium and low firewall settings in my router. Background - Earlier this year Telstra (Australia) upgraded my wifi router. I cannot b...
- Dec 31, 2016
No, the the code (C6300BD-1TLAUS) from the router wasn't recognised. I presume that is because the router has been modified/tailored to Telstra (Australia) specs and was given another code. In Netgear's Support C6300 is recognised, but not C6300BD.
Thanks for the link to the manual. But whilst the router basics appear to be the same, the sofware is different. Again, it appears to be a modification for the local market. However, the inbuilt router help provided the following Firewall security level info.
None:
All traffic is allowed.Low:Same as None, record DOS Protection/Port Scan attack to a log if DOS Protection/Port Scan is enabled.Medium:Blocks all outgoing traffic except AIM/ICQ, DHCPv6, DNS, FTP-S, HTTP ALT, HTTP, HTTP-S, IMAP, IMAP-S, IPSec NAT-T, NTP, POP3, POP3-S, RADIUS, SMTP, SSH, SMTP-S, Steam, Steam Friends, Telnet-S, XBOX Live, World of Warcraft and Yahoo Messenger.High:Blocks all outgoing traffic except DNS, HTTP, HTTP-S, IMAP-S, IPSec NAT-T, NTP, POPS-S, SSH, SMTP and SMTP-S.By lowering the level from medium to low I was able to get access to the Steam servers, which solved the immediate problem. But from what I see, the medium level should allow access to Steam (as stated). To retest, I've just reset the level back to medium and Steam is again blocked. I'm happy enough to leave the level at low, but it sounds riskier. I'll take this back to Telstra for an explanation.
Thanks again for your help.
freddiebarker
Dec 30, 2016Aspirant
Model number on router: C6300BD-1TLAUS (wasn't recognised with initial post), but believe it is C6300BD. According to the router software the hardware version is C6300BD-202.
michaelkenward
Dec 31, 2016Guru - Experienced User
freddiebarker wrote:(wasn't recognised with initial post), but believe it is C6300BD.
You mean the forum system did not recognise it?
Is it one of those oddities supplied by ISPs?
Maybe this will help:
Solved: User Manuals C6300BD - NETGEAR Communities
- freddiebarkerDec 31, 2016Aspirant
None:
