Milford_bob
Jul 18, 2018Follower
What is the difference?
Amazon sells both a C7100V and a C7100V-1AZNAS. The 1AZNAS version is about $30 less, but the specs seem identical. Can someone explain if there is a difference? Fot Comcast, will either one work? ...
antinode
Jul 18, 2018Guru
> [...] Can someone explain if there is a difference?
https://community.netgear.com/t5/x/x/m-p/1500732
https://community.netgear.com/t5/x/x/m-p/1503750
> [...] Fot Comcast, will either one work?
If either one does, then I'd bet that the other one would.
