WTFWWIW's avatar
WTFWWIW
Tutor
Jul 31, 2019
What is using my data?
Hi, I have been on the phone to comcast and they tell me that they can't give me a breakdown of my internet usage because I am using a netgear router and modem. If I was using their xfi equipment I would be able to track my data usage.
Can someone tell me how I can track data usage on my netgear equipment so I can see on a calendar month basis what device is using what data and when?
Thanks for your help.
  • FURRYe38's avatar
    What NG product model do you have?
    Try using Traffic Meter if it's supported on your NG product. This only gives a over all useage thru the router. Doesn't track anything to a specific device.
    • WTFWWIW's avatar
      WTFWWIW
      Tutor
      Thanks for the reply look for link to specific device and time on usage apparently this is all avaliable to you if you rent gear through comcast so can't believe this is a gap that netgear hasn't addressed?
      I have a CM1000 and R6300. Thanks!
