MHLane
Mar 22, 2016Aspirant
What kind of connection is a fiber cable? Any known problems hooking it to a N300 WNR2000v5?
Subject line says it all! All references to hookup say DSL or cable - not specific sort of cable. Perhaps cable is cable is cable?
DarrenM
Mar 23, 2016Sr. NETGEAR Moderator
Hello MHLane
yes if your modem has ethernet connection then you can hook it up to your WNR2000v5 just fine.
http://computer.howstuffworks.com/fiber-optic.htm
DarrenM
MHLane
Mar 24, 2016Aspirant
Hi Darren - Thanks for the reply - I have it hooked up that way. However when my wireless access computer attempts to connect it shows no internet access although it is connected wirelessly to the router. The only fix is to reset the fiber modem (router?) and then it hooks to the internet.
My wired computer sometimes acts the same way and although I have logged into the Netgear router and am on the interent right now when I attempt to log in to the router I get a -cannot display- message.
I have reset the router and gone through the set up all to no avail!
