MHLane
Mar 22, 2016Aspirant
What kind of connection is a fiber cable? Any known problems hooking it to a N300 WNR2000v5?
Subject line says it all! All references to hookup say DSL or cable - not specific sort of cable. Perhaps cable is cable is cable?
netwrks
Mar 24, 2016Master
If you purchased, or about to purcahse anything greater tha a 100Mbps Service from your ISP, you will be limited to 90ishMbps by the physical constraints of the WNR2000v5.
LAN 10BASE-T or 100BASE-Tx, RJ-45 WAN 10BASE-T or 100BASE-Tx, RJ-45.
