cmenow2
May 06, 2017Follower
What should my settings be to improve my wifi VoIP connection (QoS settings possibly)?
Model: C6900 AC1900 Cable Modem Gateway (NOT the C7000) IP: Comcast Pro (100 mbps) I'm using the Obihai1062 VoIP phone with google voice, which is connected to the C6900 Gateway via the 5G wif...
DarrenM
May 11, 2017Sr. NETGEAR Moderator
Hello cmenow2
I would check to make sure you are using the best channel for the 5ghz network.
DarrenM
