Soult3k
Apr 09, 2016Follower
What would work best for upgrading my network
Hello community!! Currently have a Netgear CG3000D. It's starting to get tapped out with multiple devices being attached. It constantly has to be re...
DarrenM
Apr 13, 2016Sr. NETGEAR Moderator
Hello Soult3k
For your setup you may be better off going with a modem and a Nighthawk router because you have a lot of devices on the network it may be more stable for you plus if you have a separate router you will get firmware updates faster since the combo units all the firmware is pushed out via the ISP.
DarrenM
