Rajesh5's avatar
Rajesh5
Where is the SSID
Hi, Just got a new Netgear CM700 cable modem with DOCISIS 3.0. This is for use with Comcast. I don't find any SSID under the unit or the box. I live in a place with 1 dozen plus wifi SSIDs, i tried connecting to anything that said Netgear, and when the password pops up (no user id, just like when connecting to any wifi) I have entered password and it does not work. I have a mac and there is no network jack to login to the gateway. Please let me know how to find the SSID. The unit is on and power is green. Does this not have a built in wifi router? Thanks
  • Modem does not have SSID. Router wirelss section has a place to create SSID. Is the modem a combo unit like
    modem and wireless router?
    • Rajesh5's avatar
      Rajesh5
      Thanks.. That may be it. Is CM700 compatable with google wifi router? i think it is generally yes but don't want to have issuse that make the combo sub optimal.
      • Rajesh5's avatar
        Rajesh5
        Can someone please confirm that the modem will work with Google wifi without any compromise? Thanks, Rajesh
