nickarino
Feb 10, 2016Aspirant
Why is sex.com not blocked on my C6300?
IN my C6300 I have gone to Advanced Tab ->Security -> Block Sites ->
* Keyword Blocking = "always"
* "block sites containing these keywords" = sex
* I updated the settings, logged out, logged in and then saw that the settings were saved.
* I see my android phone is attached to the modem by wifi
* I open up an incognito tab on the android and sex.com does load.
Why is sex.com not blocked?
- DarrenMSr. NETGEAR Moderator
Hello nickarino
Can you tell me who your service provider is and what the firmware version is of the C6300. you can find the firmware version by login into the modem at http://www.routerlogin.com/ and it should be located in the top right hand side of the page.
DarrenM
- nickarinoAspirant
We use Xfinity for our cable modem.
Firmware Version
V2.01.14
