strykerzr350
Apr 03, 2026Guide
Why is Xfinity blocking access to the spectrum analyzers?
Copied from a reddit discussion on the unofficial Comcast page. Could not get a definite answer. Recently discovered that port 8080 buy doing a port scan of the modems log in IP that Comcast is b...
strykerzr350
Apr 04, 2026Guide
So they fixed the exploit and one point in time? Seeing the CM2000 is obsolete and I am just waiting for my area to get upgraded for the next generation speeds, I suspect they kept it blocked.
I did contact them directly, then was told it wasn't blocked. I assume they got confused and thought that I meant it was about me hosting a server. Not that I was talking about a tool within the modem.
Nmap shows it is there. Like I said there is a window where it can be accessed. Nmap was used by scanning the login IP for the modem.
Apr 04, 2026Guru - Experienced User
strykerzr350 wrote:I did contact them directly, then was told it wasn't blocked. I assume they thought that I meant it was about me hosting a server.
Likely yes.
strykerzr350 wrote:So they fixed the exploit and one point in time?
The fix might have been to disable the service, or lock it down so it could only be accessed by Xfinity support. Of course there is no way to exploit the vulnerability when the modem isn't connected to the ISP, which could explain the short window you are seeing.
FURRYe38 might know if there is any way to reach the analyzer, as he once owned a CM2000.
Is this hypothetical, or is there a performance issue you are trying to troubleshoot?
