threatbuster's avatar
Jun 05, 2018
Why no firmware updates for C7800 Nighthawk
Netgear website says no firmware available for C7800 (AC3200) Nighthawk cable modem/router.  Why not?  Thanks.
    • lellsworth3's avatar
      lellsworth3
      Tutor
      While the updates to a modem/router are pushed out via the ISP, the software update *comes from* Netgear. The R7800 standalone router had security updates as recently as May 2018 it appears. My C7800 is up-to-date per Netgear documentation but has not been updated in the last 6 months as far as I know. When was the last C7800 update? If not as recently as R7800, why not? A lot of security vulnerabilities have been discovered recently...
      • michaelkenward's avatar
        michaelkenward
        Did you read the firsr reply?
        ISPs control firmware updates on cable modems.
        There is nothing that you or Netgear can do about it. The ISPs don't want anyone else messing around with hardware on their networks.
        If you have fears about the security of your internet connection, talk to your ISP.
        Or, to take back control of your security, buy a router and work out how to put your C7800 into modem only (bridge) mode.
    • dmac1026's avatar
      dmac1026
      Tutor
      That is not true theISP will not do firmware upgrades on third party modems only theirs!
