jhex7000's avatar
Oct 14, 2016
WIFI analytics App
Is there a Netgear analytics app for Windows or IOS that I can use to view channel use with my dual band cable modem?
  • jhex7000's avatar
    jhex7000
    Oct 17, 2016
    I knew I did this before but forgot - Netgear Genie for PC works fine and does the channel analytics if you dont have a supported router.
