Huddinge
Dec 30, 2015Follower
Wifi and ethernet on two Netgear CG3100
What i want is best possible wifi coverage as well as being able to easier connect multiple devices in different locations with ethernet cables, and just the one CG3100 simply didn't cut it. Luckily ...
DarrenM
Jan 05, 2016Sr. NETGEAR Moderator
Hello Huddinge
Everything looks good with your setup. The wifi issues could be a bunch of things like you said those being older models could be a bad channel that they are on. The other thing that could be causing this is a older wifi device do you have some older device using 802.11b or g if so that will drag down the speeds.
DarrenM
