Gdurney
Sep 26, 2021Apprentice
Wifi disconnection
Hello all. For about the past 2 months my modem/router has lost connection/restarted itself every night. The problem has gotten progressively worse as now it does it between 5-10 times a night sometim...
Brettmcm
I had the same problem. Do you have on the Netgear Armor? Shut it off, worked for me
- michaelkenwardSep 27, 2021Guru - Experienced User
Does the C7000 support Armor?
Doesn't look like it:
Which products support NETGEAR Armor? | Answer | NETGEAR Support
This place is getting horribly confusing with those content free "go away" messages:
Wifi disconnection - NETGEAR Communities
