JLH_2024
May 02, 2024Aspirant
WIFI disconnects intermittently - CAX80
Help!! Wi-Fi is disconnecting constantly throughout the day. My laptop is connected through my company VPN, and my wife's personal PC does not use VPN. Both computers see the same issue with Wi-Fi interruption. Xfinity has done several investigations on their end, with no issue presenting itself. I researched the problem on this forum and saw a similar issue resolved by disabling SIP ALG. I tried this and it did not work. I have rebooted the unit several times with no success, even going as far as to completely reset back to factory settings. In desperate need of help to resolve this issue. Thank you!
What devices do you have connected to the modem?
Does this happen with wired devices as well?
How is Advanced Wireless settings configured on the modem? Under Advanced Tab/Advanced Settings/Wireless Settings
What channel configurations are currently set on the router?
Any Wi-Fi Neighbors near by? If so, how many?
- JLH_2024Aspirant
Firmware is 2.1.5.2 - I have checked often to make sure this is current
Roughly 15 devices connected (phones, computers, appliances, security cams, etc)
Does not happen with ethernet connection
No Wi-Fi neighbors nearby
My 2.4ghz Channel is set to auto, 100% power, max speeds
my 5ghz channel is set to ch 36, 100% power, max speeds
Try setting manual channel 1 on 2.4Ghz and 40 on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageHas a factory reset and setup from scratch been performed since last FW update?
Any progress on this?
