brad_2k
Oct 10, 2022Follower
wifi problem
2 weeks ago, I began having Wi-Fi problems. It started 2 Thursdays ago and everyday since then my Wi-Fi goes out at 11am and doesn't come back on until 4pm. I've had a technician come out 3 times a...
Oct 10, 2022Guru - Experienced User
Are you checking the tip of the power adapter that plugs into the modem?
Should read same volts and amps using a power meter.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed?
All wired devices are working ok?
