Mschutte369
Feb 13, 2017Aspirant
Wifi router c6300 security settings and schedule
C6300. Latest firmware provided by time warner. V2.01.14, iPhones, roku tvs, surfaces, windows laptops, etc. wide variety of devices being used. I'm trying to setup a schedule to block all ports ...
PurpleCalico
Feb 18, 2017Tutor
It sounds like a bug to me. If your interface is like mine, which it sounds as though it is, if there are only a handful of devices and they already have reserved IPs, I would add them individually. If you want all ports blocked, you'll have to select Service Type: User Defined -> Protocol: All -> Starting Port: 1 -> Ending Port: 65535 -> Service Type/User Defined: Unique Name (It will not allow them to have the same name)
My issue with the schedule/block services is that it won't allow for multiple schedules, at least in my firmware...
