mr_scary
Apr 07, 2018Guide
Will not give signal or ip address to N1 router
Hello, New user here on the forums 1st post, been using Netgear products for over 20 years maybe. First issue I have ever had with Netgear Products. Let me start by saying: The CM1000 Modem is wo...
- Apr 08, 2018
Just a note:
Make sure your Router has a 1000Mbs (WAN Port) as well as 1000Mbps (LAN ports)
mr_scary
Apr 07, 2018Guide
I now at least have internet finally, But now only getting 83Mbps (83 Megabits Per Second).
If I connect the CM1000 directly to my PC I get what I'm supposed to 360Mbps (360 Megabits Per Second)
So after restarting the modem, and router several times in this order as I've done it literally thousands of times over the years. Unplug everything. Turn on Modem, wait a few minutes untill all is lights are on. turn on Router.
All equipment, and devices are working, but the speeds are way to slow.
Any Ideas... Thanks...
- mr_scaryApr 07, 2018Guide
Well, I'm gonna go ahead and say I jumped the gun by posting here.
The problem is in my opinion that even though the belking N1 Vision router is a Gigabit router,
the modem input is limited 100Mbps which is actually 83 Megabits Per Second. POS
I tried plugging the modem directly to a router port, but no go. My old DOCSIS2.0 allowed me to do that back in the day.
but I it will not work for some reason. I may keep trying.
Why will this modem not just plug into a router RJ45, and router do the DHCP.
Man I hate upgrades, its costing a fortune. I now need a Gigabit Wired Router that is compatible with the CM1000
- mr_scaryApr 08, 2018Guide
Just a note:
