xavierng
Sep 13, 2018Aspirant
Windows 10 not recognize the DM200 modem router
Hi ,
My Windows 10 OS not recognize the DM200 modem-router when I plugged in it in the PC. Any idea ? Thanks, see you.
schumaku
Sep 13, 2018Guru - Experienced User
- Power applied?
- LAN port (yellow/amber) used?
- Ethernet link and activity LED on the router green or flashing green? On the front of the DM200, lowest LED with the network icon.
- Ethernet link LED and activity LED (if any) on the PC? Note some portable devices might power-down the Ethernet port(s) if driven on battery.
- Factory new DM200 or pre-used?
- If pre-used, done a factory reset using a paper clip pressing the reset button on the DM200 back long enough to trigger a reset? Long enoug translates to some five seconds. Note any stored configuration will be lost. Once the reset button is pressed, the power/status LED does change from green to amber. After these five seconds, the power/status LED will start flashing, indicating the router is activating the default config.
xavierng
schumaku wrote:
- Power applied?
Hi schumaku ,
Power applied yes.
LAN port is green fixed.
Activity LAN PC LED have green color activity.
My DM200 is factory new device.
See you.
- schumakuSep 13, 2018Guru - Experienced User
The Windows 10 Network Interface - IPv4 Stack is configured to get IP address and DNS automatically?
Some captive portal is supposed to come up, if Edge is the default browser and there is older firmware in place (before 1.0.0.56 or the like), some controls might be missing and you have to copy the URL to an alternate browser like Chrome or Firefox.
Does it get an IP address like 192.168.5.x assigned from the router which does default to 192.168.5.1?Potentially worth a note: The DM200 LAN port speed is Fast Ethernet, just in case you have forced the interface to be Gigabit somehow (what should not be possible)
- xavierngSep 13, 2018Aspirant
Hi schumaku ,
I don't know if my Windows 10 Network Interface - IPv4 Stack is configured to get IP address and DNS automatically.
How can I check it ?
Thanks, See you.- schumakuSep 13, 2018Guru - Experienced User
xavierng wrote:
I don't know if my Windows 10 Network Interface - IPv4 Stack is configured to get IP address and DNS automatically. How can I check it ?
See the above screenshot (intentionally added the in-line photo as an attachment, too as this does become visible immediately).
Open the Control Panel -> All control Panel Items -> Network and Internet -> Network Connections. Right click on what looks like an Ethernet or Gigabit Ethernet port on your PC and go for Properties. Then find Internet Protocol Version IPv4 - select and use the new [Properties] button.
