xavierng
Sep 13, 2018Aspirant
Windows 10 not recognize the DM200 modem router
Hi ,
My Windows 10 OS not recognize the DM200 modem-router when I plugged in it in the PC. Any idea ? Thanks, see you.
xavierng
> in it in the PC.
What, exactly, does "not recognize" mean to you? As usual, showing
actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
Hi antinode ,
My Windows 10 PC not detect the DM200.
See you.
antinode
Sep 13, 2018Guru
Still no useful information. What, exactly, are you doing? What,
exactly, happens when you do it?
Are you using some web browser on your "My Windows 10 PC"? Which URL
are you giving it? THEN WHAT HAPPENS?
- xavierngSep 13, 2018Aspirant
are you giving it? THEN WHAT HAPPENS?Hi antinode ,
I try to set up the DM200.
Thanks, see you.
