BDrifty
Dec 03, 2018Aspirant
Wired Connection a lot slower than 5G WiFi
I've been running into a weird issue where my wired download speeds are much lower than my 5G WiFi speeds. When I hardwire the router to my laptop, it says the connection is the same name as the 2.4G...
antinode
Dec 03, 2018Guru
> [...] When I hardwire the router to my laptop, it says the connection
> is the same name as the 2.4G wireless band. [...]
What, exactly, says what, exactly? Did you just plug in an Ethernet
cable, or did you also tell the (unspecified) "my laptop" to use the
wired interface? "same as 2.4G WiFi" could be easy to explain if you're
still using your 2.4GHz wireless network.
BDrifty
Main issue is I shouldn't be getting 80/10 speeds on a Wired connection if I'm able to pull 300/20 on 5G wireless. Wired should always be faster.
- antinodeDec 03, 2018Guru
> [...] Wired should always be faster.
Not if your (unspecified) "my laptop" has a 100MHz wired connection.
What do the port-status LED indicators on the router indicate?- BDriftyDec 03, 2018AspirantIt lights up green just like the port designated to the Xbox One. I was able to get 300/20 on my previous modem/router combo on both laptops, but not with the Netgear one. I can only achieve the desired speeds on the Xbox One or the 5GHz wifi band with this one. Again, both PCs utilize Gig Ethernet ports as well.
- BDriftyDec 03, 2018AspirantTo be more specific, the left light, lights up for both different Ethernet ports on the router, not the right side one. They're a greenish/yellow color? I'm part colorblind. Lol
