pgreaf's avatar
pgreaf
Follower
Aug 28, 2015
Wireless Issues
I'm unable to access wireless, I have a CM400 modem connected to a WGR614 router, I can access the internet when hardwired but cannot access wireless, everyting on the devices indicate things are working, I have attempted to reset each device several times and nothing is working to fix the issue, any suggestions??
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello pgreaf
    Do you see the wireless network and cant connect to it or can you not see the wireless network at all?
    DarrenM
