YankedAround
Aug 30, 2016Follower
wireless router drops connection speed from cable modem
So I'm using a Netgear CMD31T cable Modem into Netgear G54 Wireless Router WGR614v10. I had zero problems with this set up at my previous address, however at my new address I consistently get unusabl...
Retired_Member
Aug 31, 2016There isn't much to check with that router it either works or it doesn't.
try another cable, push reset still bad replace it
