Retired_Member's avatar
Retired_Member
Feb 05, 2023
Work VPN not working on Nighthawk Ax8 combo
I've been trying so hard to work from home but all have so far failed with the gateway. All ports necessary for my work VPN have been opened, and Security taken care of, talked to my ISP and they guarantee all is well by their side, Work admin gave me all needed but I cannot get my work VPN to connect to the Nighthawk. Everything else works fine.
Please help urgently.
  • FURRYe38's avatar
    What NH router products do you have? Ax8 isn't a model #.
    R or RAX or MK something?
    • Retired_Member's avatar
      Retired_Member
      • Nighthawk' AX8/8 Stream WiFi 6 Cable Modem Router
      • CAX80-100NAS
      • AX6000 WiFi Cable Modem Router
      • DOCSIS® 3.1 - Built-in Cable Modem
      I am at work so that is what I have on the pictures I have. Would that help?
