bbxrider
Jul 12, 2017Aspirant
xfinity compatibility
this modem and a lot of others are not on the "official" comcast xfinity compability list
but I assume netgear doesn't make false claims about this
when requesting the comcast list you supply a zip code and download speed
could it be that only certain modems would be compatible within any given zip code?
- vkdeltaNETGEAR Employee Retired
which modem are you talking about? can you please give me an example
- bbxriderAspirant
ok, my mistake, I thought I had put in the model when posting
NETGEAR DOCSIS 3.0 Cable Modem (CM400-1AZNAS)
the comcast checker is here, https://mydeviceinfo.xfinity.com/
I put zip code 95608 and download speed of 25mps
I checked with your zip code. It shows as supported for 25 Mbps service.
Please see this page.
https://mydeviceinfo.xfinity.com/device/netgear-cm400-415
