Chez606060
May 18, 2018Tutor
R7000 Failed to set parental controls error
R7000 with firmware 1.0.9.26
When trying to update any connected device and change the parental control / Filer Level in Genie, I get an error of:
Failed to set parental Controls ! With Okay ...
- Jun 14, 2018
With the help of L2 Tech Support and a new firmware release from two days ago 6/12/18 Parental Controls are working again.
- Backed up settings in management GUI
- Upgraded Firmware (which was released two days ago)
- Used GUI to "Erase" for factory reset (I always hit the reset button on router)
- Un-installed Genie
- Ran through Setup Wizard GUI
- Installed Genie
- Setup Parental Controls with OpenDNS account
- Tested on numerous devices and changed settings.
All is good and thanks for the assistance.
Chez606060
May 22, 2018Tutor
Answers:
1. Have you tried resetting the router? Software Reset-Yes. Power Off Reset-Yes
2. Does the issue persist when using your other devices to change the filtering level? Yes, Three different IOS devices using Genie and all fail. Also tried using Windows 10 and it fails.
ive noticed in other threads that you eventually send an email to others that experience this too, so this appears to be somewhat common.
Chez606060
May 30, 2018Tutor
Latest update
Uninstalled Genie on Windows 10 and reinstalled
I can change Parental Control in Genie in Windows 10 and it intermittently applies filtering to some iOS devices but not all, so it’s still not working consistently
- Retired_MemberMay 30, 2018Unfortunately this didn’t work for me. I still get a login error every time I supply genie with my opendns credentials.
- Chez606060May 30, 2018Tutor
And never mind. Just went back to Windows 10 PC. I can change the Parental Control options in Genie, it retains the settings, but filtering doesn’t work.
- Chez606060Jun 14, 2018Tutor
- Installed Genie
- Retired_MemberJun 16, 2018
For some reason the Parental Controls doesn't work with IPv6. I could've sworn it did in the past, but I'm not entirely sure. So if you use this feature, you'll have to stay with IPv4.
