Chez606060
May 18, 2018Tutor
R7000 Failed to set parental controls error
R7000 with firmware 1.0.9.26
When trying to update any connected device and change the parental control / Filer Level in Genie, I get an error of:
Failed to set parental Controls ! With Okay ...
- Jun 14, 2018
With the help of L2 Tech Support and a new firmware release from two days ago 6/12/18 Parental Controls are working again.
- Backed up settings in management GUI
- Upgraded Firmware (which was released two days ago)
- Used GUI to "Erase" for factory reset (I always hit the reset button on router)
- Un-installed Genie
- Ran through Setup Wizard GUI
- Installed Genie
- Setup Parental Controls with OpenDNS account
- Tested on numerous devices and changed settings.
All is good and thanks for the assistance.
Chez606060
May 30, 2018Tutor
And never mind. Just went back to Windows 10 PC. I can change the Parental Control options in Genie, it retains the settings, but filtering doesn’t work.
Chez606060
Jun 14, 2018Tutor
- Installed Genie
- Retired_MemberJun 16, 2018
For some reason the Parental Controls doesn't work with IPv6. I could've sworn it did in the past, but I'm not entirely sure. So if you use this feature, you'll have to stay with IPv4.
