Tfgriff
Sep 15, 2017Aspirant
adding a new TL-PA 4010 (TP Link)to existing AV 500 Powerline installation
Trying to add 2 new extenders (TP-Link model TL-PA-4010 to my existiig 2 node (master/slave) existing Powerline AV 500. Sounded easy when the tech's said it would synch - driving me crazy trying to however.
It is a lot easier if you use the same brand, but the process will be something like this:
>>> Adding a powerline adapter to an existing powerline network <<<
- TfgriffAspirant
Thanks for input, you have reinforced my conclusion that I need to get the same model (version). I had seen the instruction you referenced and tried many, many times to synch the new extenders with no success. I had initially questioned the techs at the store about the compatibilty issue and should have gone with my own gut when they said it would sync with the "push of a button".
