DaveMacRae's avatar
DaveMacRae
Follower
Feb 04, 2017
Advice on extending powerline network
Hi,   In my house I have a mixture or wired and wireless networking. Main server, desktops, router, TV etc are on the wired network while laptops, chromecast, phones etc use wireless.   I'm alrea...
  • michaelkenward's avatar
    Feb 05, 2017
    You can use a Powerline plug to extend the network to the shed. I have done that. But the quality and speed you get will depend on the wiring. If it goes through a second fuse box you may lose performance.
    Sadly, Netgear, and other plug makers, don't like selling single plugs.
    There are later models. They will all work with your plugs. Some are faster but you will be limited to the speed of the slower devices.
    Plugs remember their settings, why not take the wifi plug you have indoors and try it in the shed? If it does what you want, you are in business and can buy some more plugs.
    You say the shed has Ethernet. Is that Ethernet into the house? If so, then an old router might be just as good. Better even, because the LAN should be faster than the Powerline. And no cost. No need for a main network. Once again, if you have a router just try it.
    One factor to consider, if you have fast broadband, your current plugs have 100 Mbps LAN sockets, new ones have 1000 Mbps.
