adekelver628
Sep 05, 2017Follower
Basic question after setup
A basic question. After I successfully set up my two powerline outlets, connected one to my router and the other to my laptop, will the connection on my Windows task bar show up as a wi-fi signal ic...
- Sep 06, 2017
adekelver628 wrote:
...will the connection on my Windows task bar show up as a wi-fi signal icon or an ethernet cord icon?It depends.
What are you using to view the network? What plugs do you have?
The desktop Netgear genie – not the smartest software around – has a separate entry for powerline networks.
If you have plugs with a wifi access point, then it will show as a wifi link. If they are simply wired then they appear as LAN in the genie. The genie is worth investigating if you want to control the plugs.
michaelkenward
Sep 06, 2017Guru - Experienced User
It depends.
