bigdeeeff
Nov 10, 2017Follower
Can I have Netgear and tp link powerlines on the same network
Can these co-exist and how do I sort it? Please help
michaelkenward
Nov 11, 2017Guru - Experienced User
bigdeeeff wrote:
Can these co-exist ....?
Yes.
Most recent Powerline devices follow the AV standard, which means that you can mix different makes and different generations. The only issue if that if you add "1000" plugs to a network with "500" plugs they will talk to each other at the speed of the slowest plugs on the network.
When you do add plugs to an existing network, you should follow these instructions:
Powerline Networking | Powerline Ethernet | NETGEAR
Remember, you need only one "source" plug connected to the router.
One other thing to consider, in theory you can mix brands but it isn't always easy to get set them up.
