Jasek
Nov 20, 2017Aspirant
cant get the powerline adapter to work in my out building
Heres the deal, I have an out building that is approximately 100 feet away from the house.
I set up the inside unit to the router, and set up the other unit in my out building,
It shows that there is a WIFI signal, ( which is a strong signal) but there is no internet connection!
The property is all on the sme main power coming in from the road.
I dont understand why these units are not seeing each other.
So I did this over the weekend,
I took several extension cords, and ran them from my house to the out building, and plugged the unit into the cords, and then set it all up again and, there was a good strong wifi signal and then it was connected to the internet this time!
Can anyone explain to me how, using the extension cords work and the mains dont?
I should also note that i even switched the outlet that is in the out building to the other 110volt leg in the circuit panel, thinking that it was because the outlets were on different legs, that did nothing.
Any input would be greatly appreciated,
Thanks
- clithesProdigy
Even though it's the same power supply, do you have a mini consumer unit / isolator in the outbuilding ? This could be causing the problem
- JasekAspirant
I am not sure what you mean by the mini unit?
- clithesProdigy
Can you isolate the electricity in the outbuilding as it has it's on circuit breakers?
- JasekAspirant
OK, I just looked it up, The circuit panel in the out building is just a plain ole circuit breaker panel with a 70 amp main breaker and 20 amp sub breakers.
- clithesProdigyOk, in your home your circuit breakers are all connected to the main switch, which is why powerline adapters can communicate across different circuits/phases. As you have another main switch in the outbuilding, with its own circuits/phases I think this is where the problem lies. By running extension leads you managed to keep all your units connected to circuits/phases of your main home, so this is why it worked.Not sure there's a solution, certainly not for powerline. Have you considered a wi-fi booster / repeater?
