LuckyMike
Nov 16, 2017Follower
Compatibility list
Is the PLW1000v2 – PowerLINE 1000 + WiFi compatible with the XAV 2001 adapter?
Regards
Michael
1 Reply
Yes.
Most recent Powerline devices follow the AV standard, which means that you can mix different makes and different generations. The only issue if that if you add "1000" plugs to a network with "500" plugs they will talk to each other at the speed of the slowest plugs on the network.
When you do add plugs to an existing network, you should follow these instructions:
Powerline Networking | Powerline Ethernet | NETGEAR
Remember, you need only one "source" plug connected to the router.
