srini007's avatar
srini007
Compatible powerline adapter
I currently have a XAV101 v2 powerline adapter
If i want to buy another powerline adapter, is there is a compatilbility list that will work with current XAV101 v2
  • Bin auf die Antworten neugierig. Das gleiche Problem habe ich auch.
  • michaelkenward's avatar
    michaelkenward
    They all follow an industry standard and will work together. Even different brands.
    You have an early model that is slower than the kit sold today.
    "Up to 200 Mbps with real throughput greater than 80 Mbps"
    This will limit the speed that you get with the newer, >500 Mbps, models. But they will still work.
        michaelkenward
        Good luck. It has worked here. Different standards (speedwise) and different brands. They all talk to one another.
