DualityMan
Feb 25, 2018Aspirant
Do Powerline Adapters provide ethernet line surge protection?
Hello Community, Do Powerline adapters (specifically a PLP 1000 model) provide ethernet line surge protection? With the adapter plugged directly into an unprotected outlet, I'd like to know if a sur...
michaelkenward
Feb 26, 2018Guru - Experienced User
If it can then I think I should buy a separate Ethernet surge protector.
Netgear specifically states that you should not use Powerline plugs behind surge protectors. As it says in the manual:
"Do not plug your Powerline devices into extension cords, power strips, or surge protectors."
I have used plugs on "dumb" power strips that do not interfere with the mains current. Surge protectors, on the other hand, are there to do just that. Powerline works by adding its own signal to the main circuit. You may find that surge protectors will see your powerline signal as a surge and interfere with that and wreck your Ethernet.
- DualityManFeb 26, 2018Aspirant
Hi Michael,
Thanks for responding. I agree that the adapter should not be plugged into a surge protector. I have get my PC power from a separate surge protector, so its only connection to the adapter is via the Ethernet cable. I want to protect my PC from a surge over that Ethernet cable. I'm just wandering if the adapter's Ethernet output port is surge protected. My guess is that it is not given no mention of it in the adapter specs.
Thanks
- michaelkenwardFeb 27, 2018Guru - Experienced User
I find it hard to understand how a mains surge would get down the LAN link. So your question doesn't mean much to me. I don't remember that bit has come up here before.
