AubKY
Dec 24, 2016Aspirant
Ethernet Does Not Have Valid IP Configuration
I've just purchased two XAV5201 & XWN5001 Powerline av 500 sets to upgrade my XET1001 home system. The XET1001 system works well except that transfer speeds are only around 3-5 Mbs (on my Verizon Fi...
- Dec 24, 2016
I believe I've solved my own "Ethernet doesn't have a valid IP configuration" error. My new Netgear Powerline system consists of four XAV5201 units and two XWN5001 units. When initially setting up the network I attempted to sync the entire network simultaneously, i.e., I first pressed the security button on the XAV5201 unit attached to my router and then within 2 minutes pressed the security buttons on the other five units. That appears to have resulted in the above error message on some of the units.
When I went through the process of syncing one unit at a time to the network, the error messages ceased, and now I am able to connect to the internet from each of the units.
AubKY
- michaelkenwardDec 26, 2016Guru - Experienced User
Well sorted. Nice detective work.
The issue is probably down to the fact that the two pairs of plugs were set up to talk to each other, which means that they ignore the other pair.
Your "one at a time" approach will have sorted that out.
Anyone else wanting to add news plugs to an existing pair could do worse than read this:
Adding a powerline adapter to an existing powerline network | Answer | NETGEAR Support
