Canyouhelpme
Dec 13, 2015Follower
Having Trouble connecting my Powerline 500 + WiFi (XWNB5201) NETGEAR POWERLINE AV500
I purchased the Powerline 500 + Wifi product to extend my internet from my computer room into my room on the otherside of the house. I plugged in the main adapter into my computer room and connected t...
michaelkenward
Dec 15, 2015Guru - Experienced User
First get the stuff working with the Powerline devices in the same room, where you know that they are on the same bit of the power circuit. Then you will know if it is a problem with the plugs – maybe their setup – or with the mains circuit.
