law45's avatar
law45
Tutor
Sep 21, 2018
How do I make my Wifi connection secure???
My connection is currently open and I can't get it to become secure with a password? I have tried using the powerline utility and the wifiext website and I still can't manage to get it to work. Can anyone help? Thanks
  • Solved: Go into the network genie software, click network map then right click your wifi extender device, then press configuration and it will take you to the NETGEAR AP where you can change all your wireless settings from.
1 Reply
