dkbenost
Mar 15, 2018Aspirant
How to install two adapters (PLW1000v2) to Powerline WIFI 1000
Hi.
Is it possible to have 2 outputs (PLW1000v2) with the Powerline WIFI1000?
Best Regards Bente
That should work but you will not be able to buy a single PLW1000 plug. Like most powerline suppliers, Netgear sells them as bundles with two plugs. So you will end up with a spare "base" plug. You could use that for something else like a smart TV.
Remember, when adding a plug to an existing powerline network, you need to follow this:
>>> Adding a powerline adapter to an existing powerline network <<<
- dkbenostAspirant
Thank you. Then I will stop looking for a single plug.:smileyhappy:
Do you have a 'recipe’ on how to use the "base" plug with a smart TV?
If the Smart TV has a LAN port, then you just connect the TV to the plug with a LAN cable and configure the TV to use a wired connection. Once done, that's it.
