Shimmitar's avatar
Shimmitar
I can't get more than 10 MBPS from my netgear wifi extender.
The first time i set it up, i was getting 17mbps but now i'm getting barely ten. Anyone know how to fix this?
  • nhann's avatar
    nhann
    NETGEAR Employee Retired
    Hi Shimmitar,
    Which router is connected to the extender? What speed do you receive on your router?
    Which WiFi extender are you using? Are you setting it up as extender or access point?
  • It's a verizon router and its the only one in the house. We have around 50mbps and i am using netgear powerline and for the last question i don't know.
    • JamesGL's avatar
      JamesGL
      Hi Shimmitar,
      What is the model number of your powerline adapter?
      JamesGL
      Community Team
