hangz
Dec 06, 2015Follower
is Powerline 500 compatible with powerline 1200?
Dear sir
I am using powerline 1200 package in my home. But now i need something can provide both ethernet and wifi. Can i buy powerline 500+wifi, plug in other room? Is it compatible with the power...
randomnut1
Dec 08, 2015Apprentice
You can mix them yes but your adapters will only be as fast as the slowest device in the network.
A way around this would be to pair the 1200s together with one network name and the 500s together under a different network name.
