rbmisc
May 01, 2023Aspirant
Issue with Wireless settings
I have connected to my PLW1000 via webpage and the wireless settings are WPA2-PKS(AES). But when connecting to my iPhone, it is indicating that the connection is WPA/WPA2 (TKIP). Why isn't my iPhon...
strillyl
It's possible that your PLW1000 is configured to allow both WPA2-PKS(AES) and WPA/WPA2(TKIP) security modes. Your iPhone may be defaulting to the WPA/WPA2(TKIP) mode because it is the older, more widely supported security mode.
To ensure that your iPhone is using the AES security mode, you may need to manually select WPA2-PKS(AES) in your iPhone's Wi-Fi settings. You can do this by going to Settings > Wi-Fi, selecting your PLW1000 network, and choosing WPA2-PKS(AES) from the Security dropdown menu.
Alternatively, you may need to update your PLW1000's firmware to ensure that it is properly detecting and communicating its supported security modes to your iPhone.
