CVK
Dec 01, 2015Aspirant
Laptop can't connect to Powerline
Hi
I have been using Powerline for years to extend the wifi reach in our house. Powerline is working but I can no longer connect my laptop. I think the IP address is wrong (169.... rather than 192....). I have rebooted but it hasn't worked.
Any ideas?
Thanks
Claire
A 169 IP address is an indication that the laptop is not receiving an IP address from a DHCP server, which will typically be your router.
I can think of a few things to check:
- Is the laptop using Ethernet or Wi-Fi to connect to the Powerline adapter? If it's Wi-Fi, then make sure the Powerline adapter's Wi-Fi network is set up properly. If it's Ethernet, make sure the laptop's Ethernet is enabled and that the Powerline Ethernet link light is on.
- Is the Powerline connection up? The Powerline LED should be lit (green for good, amber for fair, red for poor). If they are not lit, then you may need to repair them using the security buttons. Try doing this with both adapters plugged into the same or adjacent wall outlets.
- Is the Ethernet connection from Powerline adapter to the router up? Check the link lights on the Powerline adapter as well as router.
- Is router performing some sort of MAC Address Access Control? If so, you may need to adjust it to allow your laptop's MAC address.
- CVKAspirant
Many thanks for your quick response.
It's connected using wifi.
The Powerline connection seems strong (green lights). I've moved the adapters to the same wall right next to the router and I still can't connect to Powerline. My laptop shows Powerline with full strength but can't connect to it - neither can my phone.
Sorry I'm not technical and didn't understand your point 4!
Thanks for your help
I didn't see your answer to question 3.
Regarding point 4, do you know if your router has the ability to allow only specific devices to connect to the network?
