bernso
May 24, 2018Aspirant
Monitoring software for PLP1000
Hello
Is there a Netgear Windows 10 software available to monitor the performance of my powerline adapters ? (Like I have from other vendors)
I cannot find on the Netgear web site.
michaelkenward
May 25, 2018Guru - Experienced User
bernso wrote:
Hello
What do you want to monitor?
If you are lucky, the desktop genie can show a Powerline map. You can then "Right click" to see some information .
- bernsoMay 25, 2018Aspirant
Really I want to see very little. Just the bandwith both ways.
What is the "desktop genie" ?
- michaelkenwardMay 25, 2018Guru - Experienced User
I have never seen anythng that does that.
The local (Windows/Mac) app.
genie Landing Page | Apps | Discover | Home | NETGEAR
But it wont do bandwidth.
so far I used "TP_Link Powerline utilty" and "CPL Devolo informer" with previous CPLs.
these are simple tools that show me the bandwidth which is the critical characteristic of the CPL plugins : so many Mbits/sec this way and so many Mbits/sec the other way
I do not find the "desktop genie" on my Windows 10. I reckon it is french and may have another nickname :)
SImple file transfer seems to show my CPL are working fine, but I cannot do a file transfer every time I want to check network is fine.
