junj203
Oct 19, 2016Aspirant
Multiple Powerline Adapters
I have 2 pairs of these model powerline adapters. I am trying to get them all on the same network so I an have one main powerline adapter at the modem and the other 3 are around the home (one upstair...
- Oct 20, 2016
I put them all in the same room and they all synced up after about 3 tries, thank you, it works!
michaelkenward
Oct 19, 2016Guru - Experienced User
Take them all to the room where the modem/main plug resides.
Pair them one at a time with the main plug, using the "push button" approach.
When they are all paired and talking to the main plug, move them to where you want them.
They will remember the pairing and should then work as required.
- junj203Oct 19, 2016Aspirant
great ill try this tonight and update later
- junj203Oct 20, 2016Aspirant
- michaelkenwardOct 20, 2016Guru - Experienced User
Great. With luck you can now put them where you like and they will still talk to each other.
yes, ive moved them around to different parts of the townhouse and they are working! one room im assuming is too far from the hub so it wont light up but when i connect it outside of the room to an outlet in the hallway it works.
