junj203
Oct 19, 2016Aspirant
Multiple Powerline Adapters
I have 2 pairs of these model powerline adapters. I am trying to get them all on the same network so I an have one main powerline adapter at the modem and the other 3 are around the home (one upstair...
- Oct 20, 2016
I put them all in the same room and they all synced up after about 3 tries, thank you, it works!
michaelkenward
Oct 19, 2016Guru - Experienced User
Take them all to the room where the modem/main plug resides.
Pair them one at a time with the main plug, using the "push button" approach.
When they are all paired and talking to the main plug, move them to where you want them.
They will remember the pairing and should then work as required.
junj203
great ill try this tonight and update later
